Kampfkuchen hat geschrieben:Did you try my hint with the diagnostics mode? There is no thermostate switch for the fan. It is controlled by the ECU. I think the low-speed fan doesn't work. Maybe you have to replace the fan. If you have a multimeter, check the fan for open circuits.
Are the fuses fine?
I will send you the service manual.
commander_keen hat geschrieben:The second fan is for the air conditioning condenser.
The motor cooling fan in the V6 has two fan speeds (low-speed and high-speed),
while the 4-cylinder cooling fan has only one speed.
commander_keen hat geschrieben:If the engine coolant sensor fails, the fan is put to permanent ON. (obviously cannot be your case)
So the sensor will either most likely be okay or report wrong values to the ECU.
=> I would recommend to start testing the relais, as it's the easiest test. (and more likely root cause?)
commander_keen hat geschrieben:Yeah, correct, I already ruled that out:commander_keen hat geschrieben:The second fan is for the air conditioning condenser.
So while there is no "low speed fan", there is indeed a low speed mode for the single engine cooling fan.
And I would agree that the low speed mode seems to have an issue, because I think the temperature needle should not move while only low speed temperatures are reached.
So you must check the relais (there are three of them, where only one is for low speed mode) and maybe the temperature sensor.
Target behaviour:
When the engine coolant reaches 97°C, the engine ECU must turn on only one relais. (fan in low speed mode)
Only when the coolant reaches 108°C, the engine ECU switches on relais no.2 and no.3. (fan in high speed mode)
Therefor you need to check if only one relais is being turned on at first. Because if two relais are turned on directly after fan standing still, then you are indeed missing the low speed mode.
If you are able to remove the temperature sensor, you can test it in boiling water. Kampfkuchens manual should have a table with temperature vs. Ohms.
But be aware that it is unlikely that the sensor failed completely. Because the engineers at Mazda were clever, as they provided a failsafe: If the engine coolant sensor fails, the fan is put to permanent ON. (obviously cannot be your case)
If you never experienced two different fan speeds now although the temperature needle rises, either the ECU has a problem and doesn't switch on relais no.1 or it tries and the relais is defective. (both cases should be testable with engine hot by a simple multimeter I think?)
You should also be able to connect the low speed pins of the fan to the battery + and - directly with some wire, to see if low speed mode of the fan itself works.
Mazda RX-7 SA hat geschrieben:commander_keen hat geschrieben:If the engine coolant sensor fails, the fan is put to permanent ON. (obviously cannot be your case)
I expect that there are 2 different Sensors: one for the dash (mostly one pin connector) and a second for the ECU (mostly two pin connector).
Why I do expect this? Because in the Xedos with same V6 it is in that way. I think in the GE with 4-Zyl. it is the same.
Just as a side info.
